Motorola HCS12 Series Development Board MC9S12DP512 designed I’ve seen MC9S12DP512 car in the brain , the airbag control is used mostly used in industrial applications obviously not much information about but about the people that would work for simple convenient assay development board when I found I wanted to share .. the card’s PCB and chart drawing esgl to There is also a sample project done by drawing on resources ( portB billing ) given ..
Author HCS12 Series C or assembly language software will be promoted on MC9S12DP512 CodeWarrior IDE and programming, debugging the P & E USB Multilink mention of the device can be used
General features MC9S12DP512
16-bit bus width
25 MHz bus speed , the I2C bus
512 KB Flash, EEPROM memory for program
Data | 14 KB of RAM data to the EEPROM | 4 KByte
2x serial communication interface SCI
3x serial peripheral interface SPI
8-channel a restraining system / Timer has been extended
2x 10 -bit 8-channel | AD converter (ADC)
8-channel pulse-width modulation (PWM)
5x module 2.0 to 1 Mbps transmission rate
B CAN Programming, Debugging | BDM interface
Source: mcuhobby.cz/2010/09/vyvojova-deska-s-freescale-hcs12/
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19482.zip
Published: 2012/08/11 Tags: avr development board
dsPIC Development Board
Try dspıc30f6010 Microchip microcontroller development board on the UART (max233), can (mcp2551) and so on. find all entry and exit ports for the unit diagram and PCB design drawing eagle resources are also made with keyboard, RS232, LCD and so on. Sample C code given in the application.
