PIC16F627 RPM Measurement CPU Fan Speed Indicator Circuit
| July 30, 2024 Updated
RPM measurement circuit PIC16F627 microcontroller based on the speed of the fan is displaying on the display. Software in assembly language prepared.
PICMicro Project. measure the speed of the CPU’s fan and display it on an application in Windows or you can simply go to the BIOS Menu when the computer resets and read the fan speed directly from there.
measuring/test CPU Cooler Fans independent of the computer. And here it is, a PIC16F627 based CPU Cooler Fan Speed Tester. The speed is displayed on 4 units of 7 segment display
RPM Measurement Circuit
cpu-rpm-fan-olcum-display-speed-counter
Source: goo.gl/NcF9 RPM Measurement circiut Alternative link:
Password: 320volt.com
Published: 2010/09/06 Tags: ,
1 Comment “PIC16F627 RPM Measurement CPU Fan Speed Indicator Circuit
    Simple LDR control circuit
    Electronics were beginners can implement a simple control circuit is simple and low cost construction. Prepared circuit thanks to those who contributed.
    Circuit diagrams and printed circuit board top view of the bottom;
