Line following robot project, control of MC68HC908QB8 and PIC12F508 microcontrollers. Motor drive circuit used the L298. The system is complicated and cumbersome, but there’s a different robot projects useful sections PIC12F508-American SFH506-36 IR receiver solid (Infra Red Proximity Detector uses Sharp 38 or 40 kHz IRM) IRE5 sensor solid power supply regulated etc. is a good example of all the source codes also in MC68HC908QB8 and schematic, pcb drawings.
TTT Infra-Red Proximity Detector Kit
The TTT IRPD board utilizes a PIC12C508A to modulate two IR LED’s at 38 or 56.7KHz and look for reflections on an IR detector module. Using the TTT IRPD with another controller is simplicity itself, you can even use it on a BEAM robot because no computational power is required at all from the host computer. The IRPD requires +5V and less than 5ma total current on average, so its not very power hungry either.
This version is small and simpler to build than previous versions. There are five pins to connect the IRPD to your host controller, +5V, Ground, Left detect output, Right detect output and Enable are the connections used. The Enable pin does not need connecting unless you wish to disable the IRPD to avoid detection by passive IR sensors. The “I” pin is the Enable, its also known as the Inhibit pin, and if you pull this pin low the IRPD stops broadcasting IR and stops looking for reflections. If this pin is left high then whenever a signal is detected when the Left IR LED is flashing the L pin will go high. The same occurs when the Right IR LED is being flashed. An object straight ahead will turn both outputs on.
Source: micovo.cz/robotika-robot-v1-1.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19183.zip
Published: 2012/07/11 Tags: microchip projects, microcontroller projects
12V 240V DC Transformerless Converter IR2153 TL494
12v dc voltage 240v dc converts to 2 different circuit. someone ir2153 with the other is crafted with 100w power output drive circuits can give tl494 floor transformer obsolete high voltage, tesla circuits made with voltage diode capacitor, we see the connection there usage restricted circuits the multiplexer also aren’t very healthy fee too but it’s a different kind of application in the archive, just in case.
Note: If the ir2153 is specified in the converter with more stable
