PIC10F200 Maus modification for the game constantly keypresses
| September 5, 2024 Updated
To use the browser-based games, especially online custom modified maus and are selling a game for this circuit have keyboards I’ve heard has been placed into the online circuit maus maus, depending on the key button connects to the output of the pic PIC10F200 GP1 pin with active/passive.
For example, you need to press the left key when you’re constantly running the circuit starts:) saydırmaya bitincede. PIC10F200 asm source code in the assembly has been prepared with the software.
pic10f200-auto-mause-game
maus-hack-game-auto-button
Source: http://www.piparum.dk Alternative link:
Published: 2011/03/13 Tags: , ,
1 Comment “PIC10F200 Maus modification for the game constantly keypresses
    PIC16f628 DS18B20 Adjustable thermometer circuit
    Hello friends.
    A friend of mine and I want to share with you what I did to set the thermostat circuit. As I used the circuit temperature sensor Ds18B20. 3-digit, 7 shows the screen with dijit. Please note that the range of 0 to 99.9. When the relay circuit arranged to set value is designed to get to the bottom of the page. Set the value of 0.1 degree sensibility. Very suitable for the use of the electric heater or boiler.
    In addition to the circuit and have the tolerance setting, maybe the temperature set below the value of the operation of the relay as soon as I added something like this to disallow. The lower limit of temperature. If it weren’t for the tolerance setting, the heater is activated and disabled too often (etc) to increase energy consumption and to relay quickly melt may cause.
