Two DC DC Converters project than 1.5 volts and 3 volts, 5 volts from the 9 volt converter converter LT1073 DC to DC converter integrated circuit used in two
The LT1073 is a voltage converter DC-DC. This circuit requires only five external components in its adjustable (three components in its 5V – LT1073-5).The input voltage, which can go down to 1V allows circuit uses them for applications powered by a single stack of 1.5 V. Le courant de repos n’excède pas 135µA. The quiescent current does not exceed 135 µ A. Pour une tension de sortie de 5V le circuit For an output voltage of 5V circuit can supply a current of 40mA with an input voltage of 1.25 V and a current of 10mA for an input voltage of 1V.
The LT1073 is a voltage converter DC-DC. The input voltage is provided by two 1.5 V batteries wired in series. The quiescent current does not exceed 135 µ A. For an output voltage of 9V circuit can supply a current of 30mA with an input voltage of 1.8V
LT1073 1.5V to 5V STEP-UP DCDC
LT1073 3V to 9V STEP-UP DCDC
Source: pagesperso-orange.fr DC DC Converter Circuits alternative link:
Published: 2008/03/06 Tags: dc dc converter circuit, power electronic projects, simple circuit projects
PWM Motor and Power Control with PIC16F84
PIC16F84 4 MHz crystal is connected 100 Hz PWM output produces a pulse width of 10 separate levels are adjusted these values asm software vary from circuit only engine that not all GUS control applications can be used on a frequency of 50 Hz is set inverters driven circuit two buttons have their power levels increase or reduce the works.
PIC16F84 PWM test
Zwei Gleichspannungswandler projizieren mehr als 1,5 Volt und 3 Volt, 5 Volt aus der integrierten Schaltung des 9-Volt-Wandler-Wandlers LT1073 für Gleichspannungswandler, die in zwei verwendet wird
Der LT1073 ist ein Spannungswandler DC-DC. Diese Schaltung benötigt nur fünf externe Komponenten in seiner einstellbaren (drei Komponenten in seiner 5V – LT1073-5). Die Eingangsspannung, die auf 1V sinken kann, ermöglicht Schaltung verwendet sie für Anwendungen mit einem einzigen Stapel von 1,5 V. Le courant de repos n’excède pas 135µA. Der Ruhestrom überschreitet 135 µA nicht. Gießen Sie eine Spannung von 5 V ein. Bei einer Ausgangsspannung von 5 V kann die Schaltung einen Strom von 40 mA mit einer Eingangsspannung von 1,25 V und einen Strom von 10 mA bei einer Eingangsspannung von 1 V liefern .
Der LT1073 ist ein Spannungswandler DC-DC. Die Eingangsspannung wird von zwei in Reihe geschalteten 1,5-V-Batterien geliefert. Der Ruhestrom überschreitet 135 µA nicht. Bei einer Ausgangsspannung von 9V kann die Schaltung einen Strom von 30mA mit einer Eingangsspannung von 1,8V liefern
LT1073 1,5 V bis 5 V STEP-UP-DCDC
