ARM GPS Application LPC2148 Keil
| July 25, 2024 Updated
LPC2148 with arm gsm gps application software Keil UVision LCD display has been prepared by the source code sharing. Circuit with GPS module 3 to 7 meters of the location accuracy can determine the location. According to the less-featured navigation device designed to be used for certain jobs
The circuit operation images;
ARM GPS LPC2148
I tried to do the project with pic I had to use ARM due to resource issues. You know the account books of business. First, let me give you some information about the project. It’s location on the circuit thanks to the GPS position finding accuracy from 3 to 7 meters. This position information in speed, altitude, etc. geographical coordinates. This project will be used for vehicles such as boats, etc. for the purpose of making principal. It is designed for mobile platforms.
Target coordinates are entering the destination you are referring as navigation devices, remaining distance, distance, speed and time of arrival gives such values​​. Not here to talk vector maps available on the navigation device. Already the boat was useless b. Enter a destination, whether you take it to the target 5 meters accuracy.
lpc2148-arm-ile-gps-gsm-uygulumasi-120x120 lpc2148-arm-gps-lcd-1-120x120 lpc2148-arm-gps-lcd-2-120x120 lpc2148-arm-gps-lcd-4-120x120
lpc2148-arm-gps-lcd-5-120x120 lpc2148-arm-gps-lcd-7-120x120 lpc2148-arm-gps-lcd-9-120x120 lpc2148-arm-gps-lcd-10-120x120
lpc2148-arm-gps-lcd-11-120x120 lpc2148-arm-gps-lcd-14-120x120 lpc2148-arm-gps-lcd-15-120x120 lpc2148-arm-gps-lcd-16-120x120
lpc2148-arm-gps-lcd-17-120x120 lpc2148-arm-gps-lcd-18-120x120 lpc2148-arm-gps-lcd-19-120x120 lpc2148-arm-gps-lcd-20-120x120
lpc2148-arm-gps-lcd-21-120x120 lpc2148-arm-gps-lcd-22-120x120 lpc2148-arm-gps-lcd-23-120x120 lpc2148-arm-gps-lcd-24-120x120
lpc2148-arm-gps-lcd-25-120x120 lpc2148-arm-gps-lcd-26-120x120 lpc2148-arm-gps-lcd-28-120x120 lpc2148-arm-gps-lcd-30-120x120
lpc2148-arm-gps-lcd-32-120x120
Source: http://www.picproje.org/index.php/topic,28427.0.html ARM GPS Application Alternatice link:
Published: 2010/05/24 Tags: ,
1 Comment “ARM GPS Application LPC2148 Keil
    PIC18F4550 USB interface
    PIC18F4550 Microcontroller with USB-PC Data Transfer Interface Implementation” with PIC18F4550 computer’s USB port to transfer data detailed, useful work also PIC18F4550 features structure, the USB protocol communication circuit installation issues are presented and source software shared.
    The purpose of this study, particularly in the field of instrumentation data from peripheral devices to a computer via the USB port transfer is to quickly and reliably. From Microchip’s PIC microcontroller PIC18F4550 is produced, USB-enabled microcontroller is manufactured by processing the received signals to be sent to the computer via USB in order to fulfill the function is used. Converting analog signals to digital, especially in the computer environment to the user in a visual way to present written with Visual Basic programming language interface has been established.
