LPC2138 arm microcontroller based check point
| July 24, 2024 Updated
Though the MCB2130 inhabit has an LPC2138 microcontroller built-in, any member of the LPC213x parentage is fit for this program. The ornament can be customised to remaining members of the LPC213x, it retributory depends on the name of records the someone necessity to store in the Wink Memory. Typically, with 512KB of Radiate, it is thinkable to accumulation up to 2000 records!
arm7-circuit-lcd-keypad-card
The resources not available on the demonstration board were:
• LCD module to display information
• Keypad to enter numeric data
• Smart card interface to communicate with the Java Card smart card
• Relay output to interface inductive loads to the outside world
The hardware design is powered using a dual power supply delivering +3.3 volt and +5 volts outputs. The LCD and the relay outputs use a 5 volts power supply. The keypad, the smart card interface and the LPC213x device are powered at 3.3 volts. Author: Carlos Cossio
weeklong. In element, the tangency keeps pass of all reflexion, which can be transmitted remotely upon communicate through the RS232 program. The cast is built around a Keil MCB2130 dissent committee, and includes all the needful extraneous resources required to create as an access examine terminal.
Published: 2010/05/23 Tags: ,
1 Comment “LPC2138 arm microcontroller based check point
    LPC2132 Pc Based Ethernet Data Acquisition Control
    Designed for industrial applications, this LPC2132 microcontroller-based cast is a dependable aggregation acquisition grouping. The grouping features eight digital inputs, quadruplet parallel inputs, two parallel outputs, and a two-channel signal sideboard. Additionally, it includes two channels for passage product, which can be old to manipulate remaining devices. Assemblage is transmitted to the bread PC via Ethernet.
