All the source codes and other related instances of LPC2103 ARM have codes in addition to the LPC2103 test set the scheme also finds
Simple LPC2103 LED blinking LED blinking program for Simple program for LPC2103 LPC2103 by using GNU toolchain under uVision3 IDE, External interrupt example (EINT0) for LPC2103, ILI9320 Portrait example for LPC2103 Simple pure color screen display for inspection, the Demo example for LPC2103 board stack with a 3.5″ TFT LCD module Simple pure color display for screen inspection and PutPixel routine verified
TIMER 0 example (TMR0) for LPC2103 This example P0_8 wired to the LED blinks at a rate of 100msec with timing provided by TIMER 0 for interrupt ten match MR0. A peripheral clock speed of 15MHz assumed. This speed has been adjusted.VKP for a 12MHz 12MHz with Fcck of crystal freq = * 5, and Pclk = 12MHz * 5/4, i.e. 15MHz
LPC2103 TIMER 0 example (TMR0) using irq This example uses vectored irq with the highest priority for timer 0 to produce a 50% duty cycle on pin P0_8 (LED) with a period of 200ms. The period is configured in tmrInit (void).
Source: techtoys.com.hk/ARM_boards/LPC2103_Eval_1A/LPC2103_Eval_1A.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19890.zip
Published: 2012/10/08 Tags: arm project, microcontroller projects
Passport-PCB
Electronics, materials compon who literally though not out of purpose when used interesting and beautiful things can go 🙂 author picture in monochrome changing crop was after the PCB pressure whether from the corner hook wearing in addition for decoration SMD type of material used 🙂 I guess as earrings to use, but key would be more appropriate ..
Beispiele LPC2103
Alle Quellcodes und andere verwandte Instanzen von LPC2103 ARM enthalten Codes zusätzlich zu dem LPC2103-Testsatz, den das Schema ebenfalls findet
Einfache LPC2103 LED blinkende LED blinkt Programm für Simple Programm für LPC2103 LPC2103 mit GNU Toolchain unter uVision3 IDE, Externes Interrupt Beispiel (EINT0) für LPC2103, ILI9320 Portrait Beispiel für LPC2103 Einfaches Farbdisplay zur Überprüfung, das Demo Beispiel für LPC2103 Board Stack mit einem 3,5 “TFT LCD-Modul Einfaches reines Farbdisplay zur Bildschirmkontrolle und PutPixel-Routine verifiziert
TIMER 0-Beispiel (TMR0) für LPC2103 Dieses Beispiel P0_8, das mit der LED verdrahtet ist, blinkt mit einer Geschwindigkeit von 100 ms mit dem Timing, das von TIMER 0 für die Interrupt-10-Übereinstimmung MR0 bereitgestellt wird. Eine periphere Taktrate von 15 MHz wird angenommen. Diese Geschwindigkeit wurde eingestellt. VKP für 12 MHz 12 MHz mit Fcck von Kristallfreq = * 5 und Pclk = 12 MHz * 5/4, d.h. 15 MHz
Beispiel für LPC2103 TIMER 0 (TMR0) mit irq In diesem Beispiel wird vectored irq mit der höchsten Priorität für Timer 0 verwendet, um an Pin P0_8 (LED) mit einer Periode von 200 ms ein Tastverhältnis von 50% zu erzeugen.
