LPC1768 RTC is related applications and graphic LCD with analog clock circuit application remain in me because I made such an application. I use armor kits Keil MCB 1700 dir.saat tuning kit for use on the joystick section, I `key1 to move to adjust the hold down for approximately 2 seconds to exit the adjustment portion is enough to press the button whilst INT0. I’ve helped friends interested in these issues.
@Yamak
Source: http://www.picproje.org/index.php/topic,35348.msg260733/topicseen.html all codes (delay.c, main.c, rtc.c, rtc.h, lpc_glcd.c, lpc_glcd.h, yusuf_lpc17xx_delay.h):
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-17966.zip
Published: 2011/11/19 Tags: arm project, microcontroller projects
Proteus Isis Mixed Analog Digital Circuits
Archive 98 analog, digital isis circuit, op amp circuits, motor drivers, etc. adc circuit 555 door applications. There are also sporadic in various applications, for example to simulate plc vs LM3914 VU Meter.
Proteus isis circiut examples;
