Mono power module, based on LM3886 application. He enjoys very high popularity and good reputation even among audiophiles who are “overly sensitive to everything that is integrated”.
The LM3886 integrated circuit is based on bipolar transistors. It is equipped with protection circuitry for overheating, overload, and a very useful muting circuit for switching on and off the power supply. The delay time is determined by the RC time constant attached to the foot 8 and can be selected as desired.
The LM3886 amplifier is powered by symmetrical voltage, so there is no need for separating capacitors at the output. The loudspeaker is connected to the amplifier output via a choke with an inductance of about 0.7mH. The gland creates a few turns of wire wound on the resistor – in practice it is about 7 turns of DNE 0.8 … 1 mm on a resistor of 6 … 8 mm diameter.
The LM3886 amplifier output choke (in parallel with the 10-OHM dampening resistor) is used to protect the amplifier against the capacitive nature of the cable and loudspeaker terminals. If the loudspeaker column does not have built-in induction filters, you can risk and skip the coil using only a resistor.
LM3886 application circuit schematic
For the correct operation of the LM3886 amplifier, a symmetrical power supply with adequate current capacity is required. Keep in mind that attempting to power from a lower-power source will not only prevent the full power of the amplifier, but will interfere with its performance. The parameters obtained, especially the output power, will also depend on the supply voltage. At ± 42V and 8-OHM loudspeaker columns, you can get an output power of 90W. When powered by a voltage of ± 28 V and a 4-OHM load it will be around 68 W, ± 28 V and 8-OHM – 38 W, at ± 35 V and 8-OHM – about LM3886 50W.
Publication date: 2017/10/01 Tags: audio amplifier circuits, ic amplifier, lm3886 amplifier circuit
LM3886 Verstärkermodul
Mono-Power-Modul, basierend auf LM3886-Anwendung. Er genießt eine sehr hohe Popularität und einen guten Ruf auch unter Audiophilen, die “überempfindlich für alles sind, was integriert ist”.
Die integrierte Schaltung des LM3886 basiert auf bipolaren Transistoren. Es ist mit einer Schutzschaltung für Überhitzung, Überlastung und einer sehr nützlichen Muting-Schaltung zum Ein- und Ausschalten der Stromversorgung ausgestattet. Die Verzögerungszeit wird durch die am Fuß 8 angebrachte RC-Zeitkonstante bestimmt und kann beliebig gewählt werden.
Der Verstärker LM3886 wird mit symmetrischer Spannung betrieben, so dass am Ausgang keine Trennkondensatoren benötigt werden. Der Lautsprecher ist über eine Drossel mit einer Induktivität von ca. 0,7mH mit dem Verstärkerausgang verbunden. Die Kabelverschraubung erzeugt einige Drahtwindungen, die auf den Widerstand gewickelt sind – in der Praxis sind es etwa 7 Windungen von DNE 0,8 … 1 mm auf einem Widerstand von 6 … 8 mm Durchmesser. Die Verstärkerausgangsdrossel (parallel zum 10 V Dämpfungswiderstand) dient zum Schutz des Verstärkers vor der kapazitiven Beschaffenheit der Kabel- und Lautsprecheranschlüsse. Wenn die Lautsprechersäule keine eingebauten Induktionsfilter hat, können Sie die Spule riskieren und überspringen, indem Sie nur einen Widerstand verwenden.
LM3886 Anwendungsschaltplan
Thank you for this good source.
By the way, in a few place, it is written “V” mistakenly instead of “Ohm”.
Hi, Thanks for the feedback. Post edited.
