0-30V Regulated Digital Switching Power Supply ATmega8 LM2576ADJ
| April 9, 2024 Updated
Very high quality design of the digital power supply circuit. Voltage current of 2 × 16 lcd display of the beauty and power of the switching mode operation switching DCDC Madden LM2576 ADJ (adj = adjustable) used the output voltage 0 …30 volt current is 0.3 amps between the hex file of the source code and pcb drawings.
Meanwhile, pcb files .MDI format this format, it’s called “Microsoft Document Imaging” I just found out about it:) You may download the files as the program bmp export mdiconverter you can open programme I have option to download the file to a bmp file into the computer as not able to remi …
The circuit input voltage DC 12v … lm324 op amp supply from negative 30v lmc7660 9v-if you do not find this integrated market had obtained additional 9v transformer with symmetric +-9v regulated circuit do
microcontroller-digital-power-supply-030v-03a
Schematic-M8
atmega8-lm2576adj-dcdc-power-supply
Source: http://218.16.124.207/bbs/bbs_content_all.jsp?bbs_sn=1707407 Alternatif link:
Published: 2011/11/11 Tags: , , ,
3 Comments “0-30V Regulated Digital Switching Power Supply ATmega8 LM2576ADJ
    Open Source USB Oscilloscope Project FT245RL PIC16F690 CPLD
    Software and hardware all resources are shared open source USB oscilloscope to implement the project’s source C code (PIC16F690), CPLD Logic files, computer programs belonging to the codes (REALbasic) eagle schematics and PCB drawings are usb section FT245RL based on the system in general Xilinx XCR3128XL CPLD and PIC16F690 on the printed circuit board is very well designed ..
  2. حامد منصوریحامد منصوری
    Hello
    this cool project
    what is the zip pass?
