It can scan the books to the computer to transfer the most puzzling part to turn the pages in a professional for this job is a lot of work also have devices generating writes auto DIY book scanner with mechanical portions of the Lego robot kit is already the most puzzling according to the speed of the motor control circuitry to make the browser after mechanical stays
Automatic book scanner have motor control Robot in the source drawings prepared with LeoCad Motor Driver Circuits, you can choose an appropriate category, and Cnc control circuit
How to Make a Full Auto Book Scanner Once started, the machine opens the each page of the book and scans the content. The whole process is automatic. The lesson of this story is that LEGO is grea
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19685.zip
Published: 2012/09/08 Tags: technical video
Lego Models For Open-Source Free CAD Program LeoCAD
LeoCAD is a free open source windows and linux versions of CAD program I looked very beautiful work, very professional can reconstruct instances of Lego drawings have also illustrated the very well prepared documentation about commentaries etc. LeoCAD. There are also a lot of information now have different parts of a previous article in the 4000 automatic book scanning robot made out of lego with the system used to say we need to exceed çizimleride leocad lego kits with cac projectsbeing a very mechanical system, robots, etc..
LeoCAD is a open source CAD program that can be used to create virtual LEGO models. It has an easy to use interface and currently features over 4000 different pieces
Lego Kit mit automatischem Buchscanner Roboter
Es kann die Bücher an den Computer scannen, um den rätselhaftesten Teil zu übertragen, um die Seiten in einen Fachmann für diesen Job umzuwandeln, ist eine Menge Arbeit auch Geräte, die Schreibautos DIY-Buchscanner mit mechanischen Teilen des Lego-Robotersatzes erzeugen, ist bereits am meisten rätselhaft nach der Geschwindigkeit der Motorsteuerschaltung, um den Browser nach mechanischen Aufenthalten zu machen
Automatische Buch-Scanner haben Motorsteuerung Roboter in den Quellzeichnungen mit LeoCad Motor Driver Circuits vorbereitet, können Sie eine geeignete Kategorie und Cnc-Steuerkreis auswählen
So erstellen Sie einen vollständigen automatischen Buchscanner Nach dem Start öffnet das Gerät jede Seite des Buchs und scannt den Inhalt. Der ganze Prozess ist automatisch. Die Lektion dieser Geschichte ist, dass LEGO groß ist
