Voltage current adjustable power supply circuit is based on LM723 voltage regulator IC, the power transistors used are 2 bd249 input voltage dc 40 volt dc 1volt 37volt voltage adjustment 40 mA 3 ampere current adjustment. Also, two pots are used for current adjustment, so precise adjustment can be made. .
The regulated part of the circuit can be made as a separate floor or you can edit the pcb file. For rectification, kbu808 bridge or 4 diodes of 6 amps can be used, filter capacitor 10000uf.
Laboratory Power Supply Project
source grautier.com
Adjustable Laboratory Power Supply Circuit 37V 3A
Published: 2009/03/14 Tags: power electronic projects
Li-ion Lipo Battery Charger Circuit MAX1811 USB Powered
MAX1811 USB port on to recharge the battery produced an integrated very little material circuit can be established circuit charge status LEDs can be observed also 4.1 volts, 4.2 volts elections and 100mA 500mA charging current can be selected fed lipo li-ion battery charging circuit circuit eagle crafted with PCBs and schema files available
MAX1811 USB Powered Battery Charger
