South Korea and China electronic materials contained in the video sold at the inn, located in major business centers, shops,’s images of places. South Korea: etland, seo plaza, hacker space, seoul, Cheonggyecheon, China: Shenzhen Hua Qiang Bei Market, sega market, Shenzhen LED building
Published: 2012/06/17 Tags: technical video
KTY10 Temperature Sensor Relay Control Circuit
That you have seen in the diagram of the circuit feeding X3-1 and X3-2 is made from the ends. This 11-15V from input voltages entered D6, C8 and C9 by materials, a half-wave rectifier power supply for the circuit is provided. KTY10 on the circuit, there are two temperature sensors. These two sensor TH1, X1-1 and X1-2 ends, TH2-1, and the X2-X2 is linked to the second end. Supply of the two temperature sensors R1, C1, R2 and C2, C3, C4 via the resistor and capacitor can be ensured. TH1 and TH2 falling on temperature sensors, these sensors will change the internal resistance values P1 and C1, R5, low-power dual voltage comparator enters through out.
