ARM JTAG Programmer Circuit USB FT2232
| August 5, 2024 Updated
FT2232 USB arm jtag features: 93C56 EEPROM FT2232C, RS-232 Level Shifter (MAX3241), and changing the level JTAG port-replicator for electrical insulation ADUM1401BRW II., RS-232 connector D-SUB9, JTAG connector Arm jtag circuit’s PCB and schema files there.
ARM USB JTAG Programmer Circuit
ARM-JTAG-93C56-EEPROM-FT2232C-RS-232-ADUM1401BRW
Source: www.mcu123.com usb arm jtag programmer pcb, circuit files: alternative
Published: 2010/12/03 Tags:
1 Comment “ARM JTAG Programmer Circuit USB FT2232
    ATMega8 Bipolar Stepper Motor Driver Circuit L293B
    Bipolar stepper motor control circuit 6v … 35v inter able to run power 1 amp on the circuit control, program, sensor, PWM, UART has links ATMega8 output used in motor drive l293b circuit of the source c code ares pcb and isis simulation files there. control circuit microcontroller atmel atmega8 motor control L293
    Bipolar Stepper Motor Circuit
