The simplest radio circuit
| Updated on June 21, 2014
5 piece kit consisting of the first half pretty simple and inexpensive radio circuit with a stylish casing made ​​of wood and plexiglass think should be reinforced with output amplifier fm radio circuit has two different 🙂
simple radio circuit
I have heard, even from a physicist, that it is impossible to build FM crystal radios. On the other hand some experimenters claim that they have built them.
en-basit-fm-radyo-devresi-150x150 basit-fm-radyo-devresi-150x150
fm_radyo_devresi_crystal_circuit_2
L – 4 turns #18 copper or silver wire, 12mm inside diameter, tapped at 2.5 turns
Ant – 7 inches of #18 bare copper wire
C1 – 18 pf ceramic capacitor
C2 – 50 pf air variable capacitor
D – 1N34 diode or rock crystal
R – 150K resistor
fm-radyo-2-150x150 fm-radyo-150x150
fm_crystal_circuit_radyo_2
L – 5 turns AWG#18 bare copper or silver wire, 12mm inside diameter, tapped at 2.5 turns
D – 1N34 or rock crystal diode
C1 – 82 pf capacitor
C2 – 80 pf air variable capacitor
C3 – 18 pf capacitor
R – 150K resistor
source solomonsmusic.net
Publication date: 2009/02/25 Tags: ,
1 Comment “The simplest radio circuit
    Subwoofer Cabinet and Active Filter Circuit
    Filter and Subwoofer cabin complete with a detailed project design with TL072 opamp is shared in an active bass amp input filter for Node excel calculation sheet accounts and other drawings for the circuit pcb available in the cabin. Subwoofer enclosure made ​​of MDF
    Subwoofer Cabinet Project
