Design an old but good quality op amp cmos and transistor consisting of an Electronic Laboratory for indispensable voltage current ayal power supply circuit output stage 5 pcs 2N3055 used to control the LM741 opamp and CD4013 is used power supply chart of the printed circuit board, layout, materials list. Elon a shared circuit in electronic journals
Sharing the “ykp” Thanks to his brother.
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16159.zip
Published: 2011/09/12 Tags: power electronic projects, power supply circuit, power supply project
12V DC to DC 350V Symmetrical Power Supply Circuit SG3525
Symmetrical power supply circuit 12v input voltage +350 V-350V integrated sg3525 used to control the PWM turns. Author Lamp amp is designed to run 350volt 400mA per channel output power, in addition to strong oladıkc +15 v and 78xx series regulator depending on downs.
Dc to dc inverter circuit SMPS (switched mode power supply) works as a lamp to my mind first, but the auto amp amp jolt in the car, etc. How to use the car going. I do not know what happens. Circuit of the circuit diagram, pcb diagram ETD49 transformer windings have the information.
