Motion sensor 4 as men Header Connector can provide motion information based on the 2-position. With some effort you can make your own motion sensor on
Head Sensor Connector hook type you will use to be in the middle of four remaining sections were passed with pliers or cutters others inward turn away a large part of the work was done
Before completing the process of turning the inner side of the pins are lightly stoning case is better understood in the picture below
Grinding reason for doing that is of great importance in the operation of the sensor to the pins of the ball to ensure full contact
After the pins to be placed between the plastic tube is placed in the appropriate size cut and put a ball into
Part tilted plastic pipe inside the ball short circuit pins to the pins that are connected to the system if you happen to run a very interesting idea, nice work became a little more exaggerated or pipe the middle of the top and bottom split off the pin placed 4-position motion sensor can be made. Sensor Robot can use for your projects 🙂
source http://www.instructables.com/id/SQ7OP1FFLROKSLF/
Published: 2009/11/17 Tags: interesting projects electronics
Switched CDI Module sg3525 400V
CDI (Capacitor discharge ignition) electronic ignition module output voltage of the power of 100 watts amp 400v 00:25. Ignition system developed by Bosch is used in cars and motorcycles.
Circuit UC3525 (SMPS-control) based on the design of flyback SMPS control IC SG3525 can be used instead. Moreover, the circuit can be an example for DC-DC high-voltage applications
