Air Time or propeller clock Propeller Clock much more simple microcontrollers with can be done but the authors project quite a quality job had removed to check DSPIC30F6015 microcontroller is used BLDC motors from the hard disk removed to control the speed TB6588FGES integrated the use of the watch, as well as animation can view the RC5 control control there software C prepared by language source code library include hahil have dosyalarıda in addition TB6588 motor driver and control PIC30F6015 solid eagle pcb, schema files are also available.
Finally, the second version of the circuit have the same microcontroller used in a slightly different but more powerful hardware used large MPJET8063 engine is driven with 64 integrated LEDs STP16CP05 as in other projects feature all the resources given the same ..
Propeller Clock Circuit: Rotating LED display is very demanding in terms of precise timing and display. There are also spot-mentioned design requirements 32 (v2 64 leds) LEDs in a single row on the shoulder, brightness control refresh rate and the associated speed measurement 120 (or 240) arm positions during a single revolution, ie. angle ? = 360 ° / 120 ° = 3 ° (1.5 °) real-time clock backup battery external EEPROM for future extensions control mode with the remote control code RC-5 5 V supply
Propeller Clock circuit v1
Propeller Clock circuit v2
Source: mcuhobby.cz/tag/propeller-clock/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19925.zip
Published: 2012/11/07 Tags: dspic projects, microchip projects, microcontroller projects
Single Trigger Circuit NE555 Timer
When triggered by a button integrated in the circuit relay 555 timer is energized and immediately set is full when you leave the ignition again. working time is determined by the 220k potentiometer and capacitor C1. Receiving single trigger for the start of timing is sufficient.
Trigger Circuit Schematic Diagram
Propeller Luftschraube DSPIC Clock-Schaltung
Air Time oder Propelleruhr Propeller Clock viel einfacher Mikrocontroller mit kann getan werden, aber die Autoren Projekt ziemlich Qualität Job entfernt wurde, um zu überprüfen DSPIC30F6015 Mikrocontroller verwendet BLDC-Motoren von der Festplatte entfernt, um die Geschwindigkeit zu steuern TB6588FGES integriert die Verwendung der Uhr, sowie Animation kann die RC5-Steuerung dort Software C von Sprache Quellcode-Bibliothek vorbereitet sehen gehören hahil haben dosyararıda zusätzlich TB6588 Motortreiber und Steuerung PIC30F6015 solider Adler-Platine, Schema-Dateien sind ebenfalls verfügbar.
Schließlich haben die zweite Version der Schaltung den gleichen Mikrocontroller in einer etwas anderen, aber leistungsstärkeren Hardware verwendet große MPJET8063 Motor wird mit 64 integrierten LEDs STP16CP05 wie in anderen Projekten verfügen alle Ressourcen die gleichen gegeben.
Rotierende LED-Anzeige ist sehr anspruchsvoll in Bezug auf präzises Timing und Display. Es gibt auch punktuelle Design-Anforderungen 32 (v2 64 LEDs) LEDs in einer einzigen Reihe auf der Schulter, Helligkeits-Steuer-Refresh-Rate und die zugehörigen Geschwindigkeitsmessungen 120 (oder 240) Armpositionen während einer einzigen Umdrehung, d. Winkel? = 360 ° / 120 ° = 3 ° (1,5 °) Echtzeituhr Pufferbatterie externes EEPROM für zukünftige Erweiterungen Steuermodus mit dem Fernsteuercode RC-5 5 V Versorgung
