This project is to show the temperature information on a graphic LCD screen using the AT89S52 microcontroller, which DS1620 gives digitally.
In addition, it is aimed to notify the user that the ambient temperature increases when the circuit reaches a temperature value above 250C, and a green led lights up when the ambient temperature drops below 250C, in the same way as a red led lights up. A 12 MHz crystal clock oscillator is used to adjust the clock oscillators in the circuit.
The DS1620 is used as an 8-legged temperature sensor and also as a thermostat. The temperature is given as 9-bit data.
Display of circuit temperature is provided using a 128×64 graphic LCD. Microcontrol connection of LCD with D0,D1,D2,D3,D4, D5, D6, D7 is provided. The LCD also displays my school number at the second intervals that I set in the program.
Circuit briefly; DS1620 -> AT89S52 -> GRAPHIC LCD
AT89S52 receiving information from DS1620 displays the information with an LCD screen at the output.
Moreover, the circuit ambient temperature when it reaches a temperature above 250C is no longer a red LED lighting in the same way as the ambient temperature drops below 250C, a green LED lights up to notify user intended. 12 MHz crystal clock oscillator circuit to set the clock oscillator is used.
DS1620 is a temperature sensor and also the legs 8 is used as thermostat. Temperature is given as 9-bit data.
Demonstration of circuit temperature is obtained by using a 128 × 64 graphic LCD. LCD’s D0, D1, D2, D3, D4, D5, D6, D7 is provided with a connection to microcontrollers. Second intervals in the program I set the LCD also seems my school ID.
Thermometer Circuit schematic
AT89S52 DS1620 Thermometer Circuit keil source code and proteus isis simulation schematic files: Prepared by: @Sükriye KAYA Thanks to the People
Published: 2009/01/03 Tags: 8051 example, avr project, keil example, microcontroller projects
89C51 Digital Clock Circuit
From the incoming data encoded in Port0 integrated 7-segment display with 7447 microcontroller integrated ulaşır.7447 binary code from the 7-segment display is used to show.
So when it comes to 0000 a, b, c, d, e, f, g edu yanmaz.7 segment display LED lights bağlanmıştır.paralel parallel to each other using the same bus to the 7-segment display 7 segment display by selecting different at different times that instant If you have selected to display the data which goes to him.
what is the rar file’s password?
what is the rar file’s password cause i can’t open it
Hi,
pass: 320volt.com
