TDA9859 The main part of the preamplifier is an integrated circuit TDA9859, this integrated circuit is controlled via the I2C microprocessor Atmega128. Individual settings of the preamplifier through the keyboard are displayed on the graphical LCD display. Integrated circuit TDA9859 The preamp allows you to adjust the volume level, bass, treble, and balance in a wide range, allows you to switch between three stereo inputs, six mono inputs. The preamp also has the addition to the main stereo output also, one line output, which do not affect the setpoint correction, but only the selection of one entry. The individual parameters. The manufacturer is Philips.
Clas D Control ATmega128
Microcontroller ATmega128 A very important circuit in the entire wiring pre-amplifier is a microcontroller, which is used to control the preamplifier TDA9859, control LCD displays, data processing And a/D converter, and scanning the keyboard. The market is available a large number of microcontrollers differing between each other by the width of registers and the bus, the number of input / output ports, the number of support circuits, and also the size of program and data memory.
Among the largest manufacturer of microcontrollers partying company of ATMEL, MICROCHIP, FREESCALE, etc. because Of experience with microcontrollers of ATMEL was elected 8-bit microcontroller ATmega128 from a number of ATmega, is based on the concept of Hardwardské architecture. Processor type RISC (Reduced Instruction Set Computer), thus has reduced the number of instructions. The instructions are executed in a single clock cycle. The big advantage is the possibility of a serial programming the microcontroller directly in the application, without the need for inserting it into the programmer. On the website of the manufacturer ATMEL’s freely available development environment AVR Studio 4.
Audio Class D amplifier TAS5613
Output end of the class d amplifier was according to the needs of sound system elected to 100 W per channel, as the most suitable end amplifier was elected the integrated circuit TAS5613 company Texas Instruments, this is the circuit type “power stage”. The circuit has 4 separate channels, the speakers here are involved in the full bridge.
Integrated circuit TAS5613A is a high performance analog amplifier class-D with integrated technology with closed-loop feedback (known as PurePath HD technology). The amplifier is able to achieve output power up to 150 W (stereo) and 300W (mono) when using the speakers on the burden of 4 Ohms with a single supply voltage of 36 In. PurePath HD technology enables you to achieve performance comparable with the class AB and total harmonic distortion less how to 0,03 %. At the same time provides the energy efficiency of traditional amplifiers class D. PurePath HD technology enables to reduce losses during idle, so the device is more efficient.
digital class-d amp circuit pcb schematic all files alternative links:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25578.zip
Published: 2016/06/08 Tags: audio amplifier circuits, avr project, class d amplifier circuit, ic amplifier, microcontroller projects
TDA8929T TDA8927J Class D Amplifier Circuit Project
Class D Amplifier TDA8927J This integrated circuit includes a terminal switching transistors type DMOS (Double-Diffused MOS), circuits for controlling the transistors and circuits for communication with the control circuit. It is also equipped with a control circuit for detecting the maximum output current and temperature sensor. Further, this circuit is characterized by high efficiency, a relatively large supply voltage range, a small stalled shock and as already mentioned, it also includes thermal protection and protection against short circuit of output terminals.
Digitale Klasse-D-Verstärker Projekt TAS5613 TDA9859 ATmega128
TDA9859 Der größte Teil des Vorverstärkers ist eine integrierte Schaltung, TDA9859, dieser integrierten Schaltung gesteuert wird über den I2C-Mikroprozessor Atmega128. Individuelle Einstellungen der Vorverstärker über die Tastatur werden angezeigt, die auf der graphischen LCD-Anzeige. Integrierte Schaltung TDA9859 Der Vorverstärker können Sie zum anpassen der Lautstärke, bass, treble und balance in einem weiten Bereich, ermöglicht es Ihnen, zwischen drei stereo-Eingänge, sechs mono-Eingänge. Der Vorverstärker hat auch die neben dem stereo-main-Ausgang, ein line-Ausgang, die keinen Einfluss auf die Sollwert-Korrektur, sondern nur die Auswahl von einem Eintrag. Die einzelnen Parameter. Der Hersteller ist Philips.
