Digital Class D Amplifier Circuit TAS5706A PCM1850A ATmega128
| Updated on August 4, 2019
TAS5706A Class D Amplifier was itself the signal processor. From this parts depend all the other elements. Has an impact on the type of power supply, the control method of the type converter. That is why he was first selected DSP processor.
There are more firms that produce the processed signal processors whose internal connection is possible in many ways to reconfigure. However, the need was that the management was as simple as possible, therefore, programmable signal processors are discarded from consideration. Was selected processor TAS5706A from the company Texas Instruments. TAS5706A is a digital signal processor with fixed elements*1 and integrated by the final degree class D.
TAS5706A Class D Amplifier Circuit Schematics
schematic-circuit-tas5706a-amplifier-pulse-width-modulation-pwm-pcm1850a-diagram-120x120 class-d-digital-signal-processor-tas5706a-dsp-spi-i2c-pcm1850a-120x120 tas5706a-control-unit-atmega128-and-power-supply-120x120
The digital audio signal is received from A/D into the DSP via four wires. SDIN (serial data in) is input navzorkovaných data. MCLK (master clock) is input signal has the highest frequency. SCLK (serial clock) is the input additional hour
PCM1850A from the company Texas Instruments. The converter was set into a fashion master, has the task to create hourly signal, and send the data separately. He was elected the format of left-justified with sampled by frequency of 48 kHz and a resolution of 24 bit. From the catalog letter [4] was to see that it is fully compatible with TAS5706A.
class-d-amplifier-circuit-transistor-amplifier
PCM1850A contains: 6 stereo inputs multiplexovaných, up to 24 bit resolution at the sampling frequencies of (16-96) kHz, Delta-Sigma A/D converter, anti aliasing filter, option mode the master or the slave, left-justified, I2S and right-justified output format, 256x, 384x, or 512x resampling, the output decimačný filter 64x upscaling.
ATmega128A is an 8-bit RISC mikrokontrolér with 128 kB memory for program FLASH, 4 kBram, SRAM and 4 kB memory EEPROM. Contains 8 and 16 bit counter, timers along with the generators PWM. The hardware-implemented blocks to support communication via the SPI and I2C. The computational performance on the taktovacej a frequency of 16 MHz up to 16 MIPS.
circuit-tas5706a-amplifier-pulse-width-modulation-pwm-pcm1850a-120x120 tas5706a-audio-amplifier-circuits--120x120 tas5706a-class-d-pcb-120x120
srcb tas5706a class d amp circuit pcb schematic all files alternative links:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25654.zip
Publication date: 2016/06/14 Tags: , , , ,
2 Comments “Digital Class D Amplifier Circuit TAS5706A PCM1850A ATmega128
    Adjustable SMPS Laboratory Power Supply UCC28600 0-30V 5A
    Adjustable Laboratory Power Supply SMPS design a lab power supply switching concept, which will work in kvazirezonancním fashion. The source should have one symmetrical output 0 to ±30 V / 5A (UCC28600) and one output single-ended +5V / 2A. (TOP243) Equipment opatrete digital indication of the output voltage and current and the electronic protection during short circuit. Characteristics of the resources to simulate in the program PSpice, design of each board printed circuit con in the Eagle program.
    Digitale Class-D-Verstärker-Schaltung TAS5706A PCM1850A ATmega128
    TAS5706A Klasse-D-Verstärker war das signal-Prozessor. Aus diesem Teile hängen alle die anderen Elemente. Hat Auswirkungen auf die Art der Stromversorgung, die control-Methode der Typ-Konverter. Das ist, warum er war der erste gewählte DSP-Prozessor.
    Es gibt mehr Firmen, die produzieren das verarbeitete signal-Prozessoren, deren interne Verbindung möglich ist in vielerlei Hinsicht neu zu konfigurieren. Aber der Bedarf war, war das management so einfach wie möglich, deshalb, programmierbare signal-Prozessoren werden verworfen, aus Rücksicht. Ausgewählt wurde-Prozessor TAS5706A von der Firma Texas Instruments. TAS5706A ist ein digitaler signal Prozessor mit festen Elementen*1 und integriert von der Abschluss Klasse D.
