Desoldering Pump Cleaning
| Updated on April 17, 2024
“Cleaning the Desoldering Pump” was one of my duties during my apprenticeship years 🙂 Even though I don’t clean it as thoroughly as in those days, it still works. Note: You can obtain the plastic part used to protect the pump tip from the EHT transformer of tube televisions and monitors. The bottom part of the vacuum plastic of the high voltage cable..
Publication date: 2024/04/17 Tags:
