TTL CMOS Databook Program
| July 13, 2023 Updated
IC-Databook free handy catalog for 40 and 74 series integrated. program 230 has integrated information from the Edit menu additions you can make in the Datasheet and Directory partition information is stored in txt file
In this IC-Databook Software you will find pin assignments, connection layouts, function tables and the most important specifications available for the 40x and the 74x IC series. In the actual software version are already the data of more than 230 different IC’s. You can easily add additionally IC’s add or edit existing IC’s and exchange them with other users.
lojik_ttl_cmos_entegre_katalog
Source: progshop.com/shop/software/databook/databook.html TTL CMOS Databook Program Alternative link:
Published: 2008/09/29 Tags:
1 Comment “TTL CMOS Databook Program
    PIC16F827 Remote Controlled RGB Light Bulbs Lamp Project
    Previously PIC16F628 and a similar share had been made in this project is more or less there used microcontroller pic16f627 3 pieces 220v 40w 60w can be used MOC3020 Optodiyak isolation from the provided pic Supply 6 volt transformer made ​​by this way the system is isolated load is used to control Triac BT137 circuit diagram detailed description and the source code there. RC5 protocol is used for the control circuit controls
    This RGB light I designed and built a while ago. A large spectrum of coloured light can be made mixing light from bulbs coloured in red, green and blue. So, this one is not based on LEDs but it’s based on 3×60W 220/110Vac light bulbs. Also, it has a remote controller to change intensity of the three bulbs, store and recall preferred hues, turn the thing on and off.
