ATMEL AT89 series programmer circuit (working tested)
| July 5, 2023 Updated
ATMEL AT89 series with the circuit programmer can program many microcontrollers. Programming circuit integrated with different number of pins used for two ZIF socket.
Circuit running through the RS232 serial port of the computer AT89C51-C52-S52 89series4.hex file without installing the integrated scheduler to work. Project of the diagram, pcb printed circuit board, software and computer programs have hex.
atmel-programlayici-atmel-programmer
Specifications ATMEL AT89 series programmer circuit;
  • Supports major atmel 89 series devices
  • Auto identify connected hardware and devices
  • Error checking and verification in-built
  • Lock of programs in chip supported to prevent program copying
  • 20 and 40 pin zif socket on-board
  • Auto erase before writing and auto verify after writing
  • Informative status bar and access to latest programmed file
  • Simple and easy to use
  • Works on 57600 speed
Integrated Supported for the ATMEL AT series;
Flash (Kbytes) EEPROM RAM (Bytes) I/O Pins
AT89C51 4 128 32
AT89LV51 4 128 32
AT89C52 8 256 32
AT89LV52 8 256 32
AT8C55 20 256 32
AT89LV55 20 256 32
AT89S51 4 128 32
AT89LS51 4 128 32
AT89S52 8 256 32
AT89LS52 8 256 32
AT89S53 12 256 32
AT89LS53 12 256 32
AT89S8252 8 2 Kb 256 32
AT89LS8252 8 2 Kb 256 32
AT89C1051 1 128 15
AT89C2051 2 128 15
AT89C4051 4 128 15
Source: http://www.kmitl.ac.th/~kswichit/89prog/index.html ATMEL AT89 series programmer pcb schematic pc program Alternative link:
Published: 2008/03/02 Tags:
2 Comments “ATMEL AT89 series programmer circuit (working tested)
    Professional Amplifier Circuits 450W 180W
    Quality pcb printed circuit design with two amp circuit I share 180 watt amp circuits used in power output transistors 2sa1943 2sc5200 supply voltage + -45 volts DC P-CAD 2001 prepared by the PCB and P-CAD 2001 Schematic prepared by the schema file there.
    450 watt amp features the same count in the circuit and transistor supply voltage is higher than the number
    Programmierschaltung der ATMEL AT89-Serie (funktionsgeprüft)
    Die ATMEL AT89-Serie mit dem Schaltungsprogrammierer kann viele Mikrocontroller programmieren. Programmierschaltung mit unterschiedlicher Anzahl von Pins für zwei ZIF-Sockel integriert.
    Schaltung läuft über den seriellen RS232-Port der Computerdatei AT89C51-C52-S52 89series4.hex, ohne den integrierten Scheduler zu installieren. Projekt des Diagramms, Leiterplatte, Software und Computerprogramme haben hex.
    ATMEL AT89-Serie Programmierschaltung (funktionsgeprüft) atmel programlayici atmel programmer
    Technische Daten Programmierschaltung der Serie ATMEL AT89;
    Unterstützt wichtige Geräte der Atmel 89-Serie
    Angeschlossene Hardware und Geräte automatisch identifizieren
    Fehlerprüfung und Verifizierung eingebaut
    Sperre von Programmen im Chip wird unterstützt, um das Kopieren von Programmen zu verhindern
    20- und 40-poliger Zif-Sockel an Bord
    Vor dem Schreiben automatisch löschen und nach dem Schreiben automatisch überprüfen
    Informative Statusleiste und Zugriff auf die zuletzt programmierte Datei
    Einfach und leicht zu bedienen
    Funktioniert mit 57600 Geschwindigkeit
