Thermostat circuit for 2 pt100 temperature measurement used atmega8 mikrüdenetleyici sensor pt100 sensors gives the circuit output is being used according to the information received. The thermostat is located on the circuit board led display temperature value. Connect the relay outputs can be controlled by a variety of devices, TRIAC, etc. PT100 sensor, Thermostat for the project in the c source code and eagle pcb, schema drawings.
Source: lubosweb.php5.sk/konstrukcie/06_termostat_pt100.php alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19043.zip
Published: 2012/06/11 Tags: atmega8 projects, avr project, microcontroller projects
S65 Siemens LCD examples Circuit ATmega16 ATmega32
Before “Siemens S65 LS020 glcd ATmega128 AVR” shared examples of implementation through a lot of similar projects with ATmega16 ATmega32, microcontrollers. A few of them; Image via representation of FAT16 MMC card color, font samples, etc. based on a stylish also the atmega16 S65 test activity..
