Led effect circuit 64 leds LEDs on the printed circuit board disposed in the impeller has a very different effect. A plurality of circuit components used SMD type. Effects displacement, velocity pcb solder buttons mounted face. Source code for the project and provided drawings eagle pcb diagram.
Source: paja-trb.unas.cz/elektronika/konstrukce/snowflake.html
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18421.zip
Published: 2012/01/26 Tags: atmega8 projects, avr project, led projects, microcontroller projects
High Power PWM Circuit 555 Mosfet
In the diagram you can see the circuit, which integrates popular NE555 is used. This integrated using the PWM of a DC motor and / or a lamp is driven by PWM pulses. Together with the engine, the purpose of the lamp using the N-channel MOSFET is from obtaining a strong output. Of course it can change according to your own mind or you can remove. If the PWM, we have achieved through a pin PALS is a variable width.
Die LED-Effektschaltung 64 LED auf der Leiterplatte, die im Flügelrad angeordnet ist, hat einen sehr unterschiedlichen Effekt. Eine Vielzahl von Schaltungskomponenten verwendet den SMD-Typ. Effekte Verschiebung, Geschwindigkeit Leiterplatte Lötknöpfe montiert Gesicht. Quellcode für das Projekt und mitgelieferte Zeichnungen Eagle PCB-Diagramm.
