Led Clock Thermometer circuit based on the appearance of a lot of trouble, but construction of the ATmega8 microcontroller is very beautiful like a 900 LEDs used LEDs positioned on the plate tabelarda Atmega8 outputs there are outputs 4 x 74HC574 is IRF8910PbF (two single package mosfet of smd so8 sheath) mosfet powered through the different pcb regulation of N-channel mosfet are available on the market.
Thermometer Clock DS1307 Circuit schedule for the time being used in indoor and outdoor temperature measurement within IC two DS18B20 sensor is used. Proteus isis simulation, source code file to the project and have been prepared with the main card sprint layout pcb artwork.
source: mdoga.ru alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22969.zip
Published: 2014/05/06 Tags: atmega8 projects, avr project, led projects, microcontroller projects
Compact Stereo Amplifier Project
A previous article, I shared my “TDA7294 Stereo amplifier circuit of controlled Loudspeaker-protected tons of” project was a more compact amp. Designed for use on my computer.
Amplifier TDA2030, popular with LM1875, the sight of TDA2040, can be used in a one-to-one connections this amplifier circuits TDA2050 integrations are compatible with different output power and audio quality for detailed information, please refer to the datasheet files suggestion LM1875 or TDA2030 integrations (ST with the logo of the original).
Led-Uhr Thermometer Schaltung ATmega8 DS18B20
Led Uhr Thermometer Schaltung auf das Aussehen der eine Menge ärger, aber die Konstruktion des ATmega8 mikrocontroller ist sehr schön wie ein 900 LEDs LEDs positioniert auf der Platte tabelarda Atmega8 Ausgänge gibt es Ausgänge 4 x 74HC574 ist IRF8910PbF mosfet angetrieben durch die verschiedenen Leiterplatte regulation der N-Kanal-mosfet auf dem Markt erhältlich sind.
Odlično; evo nešto slično iz 2015
http://fema-hobi.blogspot.com/2015/10/prosvijetlio-novi-sat.html
http://fema-hobi.blogspot.com/2015/09/novi-sat-iz-moje-radionice.html
