AT89C51 L293D DC Motor with Door Control Circuit
| July 9, 2023 Updated
The main purpose of the circuit is to control the gate of the house. This DC motor and provided with two limit switches is provided by mechanical parts. The two buttons open and close the circuit inside is available. Sent to the ends of the drive motor integrated into 1 and 0 knowledge engine is turning left or right.
AT89C51RD2 switches are connected in series to the output port. As soon as the door closed one of the key information by sending port is disconnected. When the other button is pressed, this time the information is sent to one of the other ports and the engine returns to the other side and this time it is connected to the switch port opens.
L293D DC Motor Door Control
maket_ev_proje_1
maket_ev_proje_3
l293d
L293D DC Motor Door Control Schematic PCB
maket_ev_devre
maket_ev_pcb
L293D PIN connecting
l293d_diagram
Output Ports Connection Diagram with Motor Drive
port_baglanti_sema
AT89C51 L293D DC Motor with Door Control proteus isis schematic pcb keil source code
author: Ergin YILMAZ
Published: 2008/06/02 Tags: , , ,
1 Comment “AT89C51 L293D DC Motor with Door Control Circuit
    PIC16F628A Line following robot project
    Line following robot project with a more powerful battery and the engine was a good guess but it can result in opportunities, folks have the best hand made ​​based on PIC16F628A circuit used for the detection sensor CNY70 L298 used for motor control
    Line following robot control board
