AT89C51 Square Wave Signal Generator
| July 9, 2023 Updated
Signal generator test is often the recipients of the amplifiers used in the test and repair of this equipment. Used as the signal source. Wave detector, radio frequency used in places such as bridges. Integrated signal generator, the steady operation, because of the cost is low and it is preferable to be mixed. Attractions signal generator used in the experiments 1Hz – 10Hz and 100Hz frequency will produce. When prompted, the program used can be obtained by varying the maximum 500MHz square wave signal.
AT89C51 Square Wave Signal Generator pcb schematic keil source code
AUTHOR: Birkan GÖÇERLER
Published: 2008/06/07 Tags: , , ,
1 Comment “AT89C51 Square Wave Signal Generator
