Sold in the market potency heat settings with TRIAC 220v temperature-controlled soldering iron more advanced version control AT89C2051 microcontroller is provided by heat setting 2 button is made with indicators, one for led display used temperature% are read.
Control circuit with triac driver moc3041 opto-isolated circuit diagram Triac T he G Gheit stated as the cathode and the anode K can use triac BT138. Source C code given to the project.
Digital Soldering station circuit
Source: ahtoxa.net/micros/at89c2051/power-reg
220V Soldering Iron Temperature Control with AT89C2051 LED Display
Password: 320volt.com
Published: 2011/01/10 Tags: avr project, microcontroller projects
Hot Air Gun Soldering Control MSP430F2013 Project
MSP430 series microcontrollers use is increasing day by day I’m sure these habits will further increase is not primarily about MSP430 MSP430 For detailed information I suggest you look into writing about
Of an electronics circuit that uses a lot of hot air station provides control of the application rather than being a ready power control with MSP430 project will work in the application source code that could limp printed circuit diagrams have all the resources.
