Arduino Uno kit on the Board at the entrance of the TL082 opamp used Guitar Tuning circuit audio audio input and frequency to detect the “Arduino-Frequency-Detection” software used.
According to the LEDs light at certain frequencies sesisnin the guitar.
E – 82.4 Hz
A – 110Hz
D – 146.8 Hz
G – 196Hz
B – 246.9 Hz
E – 329.6 Hz
Guitar Tuning system works with 2 pieces of 9v battery connection diagram and source code box for the panel was given in diagrams (corel, photoshop)
source: instructables.com/id/Arduino-Guitar-Tuner/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22706.zip
Published: 2014/02/22 Tags: arduino projects, avr project, microcontroller projects
Electronic Piano Using PIC microcontroller (PIC18F4550)
Electronic piano circuit PCB printed circuit board drawing upon the Pic18f4550 microcontroller PIC has been a regular speaker on the card directly to number 2 in the pin of this RA0-Pic18f4550 AN0 pine bjt, mosfet transistor or the amplifier can be increased by adding volume.
Gitarren-Abstimmung Projekt mit Arduino
Arduino Uno-kit auf der platine am Eingang des TL082 opamp verwendet, Gitarren-Tuning-Schaltung audio-Eingang und-Frequenz zu erkennen, die “Arduino-Frequenzerkennung ” – software verwendet.
