Circuit TL084, 555, CD40106 integrated based on the driver, b, fuzz, two band pass filter, tone genarate 1.2, LFO controls able modulation depth can be adjusted circuit supply 9-volt battery provided with further circuit schematic drawing in sections for different applications helpful may
Analog Sound Effect Circuit
source: casperelectronics.com
Published: 2009/06/15 Tags: audio control circuits
CCS C Sumo Robot Project PIC16F876
Design a perfectly good sumo robot design and control circuit pic 16f876 based on the motor drive lm293d drizzle detection for the sharp gp2d12 sensors used hardware and software in detail about (english) Information Additional file given in (. Doc) all sources CCS C software’s. Suma quite powerful robot body looks very well designed for various robot projects a body design was to be imitated
The PIC 16F876 is a very powerful micro-controller. In addition to the hardware features mentioned above, the software for Seeker II is fairly advanced. The main control loop is implemented as a formalized finite-state machine (FSM). Using an FSM eases the code management problems inherit in any complex piece of control software. The states currently implemented are as follows:
PIC16F876 Sumo Robot Project
