oil alternative fuel economy quest many have research Aleix Llovet and Xavier Salueñ about this interesting work has been done name dalh2ore a few pieces of aluminum sodium hydroxide substance mixed with chemical reactions as a result of hydrogen is obtained for this job only add fuel their model cars 40mn. 30km per hour is going fast ..
Published: 2012/11/07 Tags: technical video
DSPIC Propeller Clock Circuit
Air Time or propeller clock Propeller Clock much more simple microcontrollers with can be done but the authors project quite a quality job had removed to check DSPIC30F6015 microcontroller is used BLDC motors from the hard disk removed to control the speed TB6588FGES integrated the use of the watch, as well as animation can view the RC5 control control there software C prepared by language source code library include hahil have dosyalarıda in addition TB6588 motor driver and control PIC30F6015 solid eagle pcb, schema files are also available.
Die Reaktion von Aluminium mit Wasserstoff-Brennstoffzellen
Öl alternative Kraftstoff Wirtschaft Suche viele haben Aleix Llovet und Xavier Salueñ Forschung über diese interessante Arbeit wurde getan Name dalh2ore ein paar Stücke von Aluminium-Natriumhydroxid-Substanz mit chemischen Reaktionen als Ergebnis von Wasserstoff gemischt ist für diesen Job erhalten nur Kraftstoff ihre Modellautos 40 Minuten. 30 km pro Stunde gehen schnell
