The author uses AVR microcontrollers, but has a structure that can be used with different microcontrollers.. button, LED, switch, LCD, etc. gather the cards together and made a single card as well as passive recreational module
– Keyboard Matrix (number of rows – 4, number of columns – 4);
– Chapter separate and independent buttons (number of buttons – 16);
– DIP-switch (the number of independent control lines – 32)
– Number of encoders – 2 a clock you can use the encoder with the button);
– LCD Module (2 line 16 characters);
– 7-segment LED Display (Display digits / characters maximum number of – 6);
– LEDs (number of LEDs – 32);
– audible warning buzzer (s – 3).
source: we.easyelectronics.ru/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25441.zip
Published: 2016/04/22 Tags: avr development board
Calculator Circuit with PIC18F452
the PIC18F452 is a simple calculator circuit that can process that I did with 4.You can enter the five-digit numbers.(for Word).Also able to make fractional calculations.After you find do an operation and the result is a new transaction in order to make them “equal” you must press the button.If you have any questions on the program if you want to restart or “reset” button you can press.For what I did to a fellow student can perform simple operations only.It’s up to you to develop open codes and publishes…
PIC18F452 Calculator Circuit
Zusätzliche Karte Modul Für Mikrocontroller-Projekte
Der Autor verwendet AVR-mikrocontroller, hat aber eine Struktur, die verwendet werden können, die mit verschiedenen Mikrocontrollern…”, LED, Schalter, LCD, etc. sammeln Sie die Karten zusammen und machte eine single-Karte als auch der passiven Freizeit-Modul
