15V Symmetrical Power Supply Circuit 7815 7915
| September 5, 2024 Updated
78XX and 79XX negative positive regulator ICs, you can easily supply circuit with the series regulator circuits. This circuit gives a nice symmetrical +-15v output printed circuit desing there is a list of the material scope of the pcb, etc. shared images of the schema.
simetrik-regulator-circuit-7815-7915-power-supply
Source: http://www.siliconchip.com.au/cms/A_112363/article.html Alternative link:
Published: 2011/03/14 Tags: , , ,
1 Comment “15V Symmetrical Power Supply Circuit 7815 7915
    PIC10F200 Maus modification for the game constantly keypresses
    To use the browser-based games, especially online custom modified maus and are selling a game for this circuit have keyboards I’ve heard has been placed into the online circuit maus maus, depending on the key button connects to the output of the pic PIC10F200 GP1 pin with active/passive.
    For example, you need to press the left key when you’re constantly running the circuit starts:) saydırmaya bitincede. PIC10F200 asm source code in the assembly has been prepared with the software.
