Amplifier Circuits 1W 2.5W TDA7052 LM386 LM380N
| Updated on August 3, 2019
Low-power audio applications frequently used LM380N, crafted with LM386 amplifier circuits 3 TDA7052 amplifier circuit. the same for all the integrated master PCB prepared drawing seems a just some elements of the settlement changed by this different integrated circuits.
1W amplifier 2 .5W Amp circuits, standard power indicator led, power switch and dimming potentiometer input 6.3 mm jack plug. LM386: 5V–12V TDA7052: 5V. 12V LM380N: 9V …20V DC voltage.
tda7052-circuit-lm386-circuit-lm380n-circuit
tda7052-lm386-lm380n-pcb-printed-circuit-boards
The author be portable and sound quality for the 9V battery connection has given information about the settlement plan prepared. For example, LM380N can work with high volume in order to get 9v only 20v battery instead of 2 x 9v battery can be obtained by connecting the battery voltage of the serial link serial-18v to increase batteries connected in parallel increases the power (batteries are going to be the same) can also be used instead of the proper voltage adapter battery
pil-seri-pil-paralel-battery-series-connection-battery-parallel-connection
source: faxter.es/Proyectos/Pr04Miniamplificadoresport%C3%A1tilesMiniGP/tabid/99/Default.aspx Alternatif link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21918.zip
Publication date: 2013/08/04 Tags: , ,
2 Comments “Amplifier Circuits 1W 2.5W TDA7052 LM386 LM380N
    Headphone Amplifier TDA2822M
    According to the size of the force is quite a popular TDA2822M amplifier IC is used in computer applications, as well as headphone amp seslendirmesinin connection according to the shape of the stereo or bridge connection with single channel can give higher audio.
    The author used as a headphone amplifier 4 ohm 8 ohm or 32ohm speaker kullaklıklar says that good results with high-impedance headphones (100 Ohm, 600 Ohm) talks about the perfect functioning of the circuit, but with the sound level is lower than the
    TDA2822M amplifier circuit
    1W 2,5W Verstärker Schaltungen TDA7052 LM386 LM380N
    Verstärker Schaltungen Low-power-audio-Anwendungen Häufig verwendet, LM380N, gestaltete mit LM386-Verstärker-schaltungen 3 TDA7052 Verstärker-Schaltung. das gleiche für alle, die integrierte master-platine vorbereitet Zeichnung scheint nur einige Elemente der Siedlung änderte sich durch diese verschiedenen integrierten schaltungen.
    1W-Verstärker 2 .5W-Amp-schaltungen, standard-power-led-Anzeige, power-Schalter und DIMM-potentiometer-Eingang 6.3 mm jack-plug. LM386: 5V–12V TDA7052: 5V. 12V LM380N: 9V …20V DC Spannung.
