Led flash circuit 180 leds optionally control solid canceled and the only lighting available in LEDs for current limiting made printed circuit board layout beautiful circuit has two positions, if desired NE555 floor can be adjusted with the LEDs flashing (together) are provided or LM358 times the audio input flashing making offers.
Pcb circuit layout drawings prepared by the sprint layout “http://www.abacom-online.de/uk/html/dateien/demos/viewlayout50.exe”
Source: hobbielektronika.hu/kapcsolasok/led-es_stroboszkop.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18412.zip
Published: 2012/01/22 Tags: 555 timer circuits, analog circuits projects, led projects, simple circuit projects
Information Labels for Atmel AVR Microcontroller
The AVR-based project will facilitate your work in a simple but useful is the author of the popular avr microcontrollers with a knack for pin input, output, etc. is written label templates made of DIP used on pasting so integrated into the sheath connection error such as it’s hard to be more States also are more comfortable reading disabled. If you receive more useful color printer output.
LED-Blinkschaltung 180 LED-Anzeigen steuern optional dauerhaft aufgehoben und die einzige in LED-Anzeigen zur Strombegrenzung verfügbare LED-Anzeige hat zwei Positionen. Falls gewünscht, kann der NE555-Fußboden eingestellt werden, wobei die LED-Anzeigen (zusammen) blinken oder LM358 vorgesehen sind mal den audioeingang blinkend machen bietet.
