Quality power Amplifier circuit a famous brand’s clone version of the “Krell KSA-50” 8Ω speaker with a 70w rms power can give is said output transistors mj21193 and mj21194 circuit schematic, printed circuit board views from the top all the drawings and gerber files are
Krell Clone 150W Amplifier Circuit
150W Amplifier Circuit schematic pcb files
150W Power Amplifier Circuit MJ21194 MJ21193 Transistor
Published: 2010/01/06 Tags: audio amplifier circuits, transistor amplifier
Expansion to 32 Channels Parallel Port 74HCT573 LPT Relay
I previously shared circuit “Computer with Device Control” writing output thanks to the integrated circuits have been replicated so 74hct573 (32) also with source code control program has two This circuit allows connecting up to four power control modules to the same parallel port. This port need not be bidirectional, so any PC oldest will be to control this system.
