12V 60AH Car Battery Repair Desulfator Test
| Updated on December 17, 2024
I did the time test of the Advanced Battery Desulfurizer Circuit circuit that I shared before with a 12V 60A Car battery. I will keep the desulfurizer connected to the battery for 1 month but I wanted to share the first result, I got very good results in about 1 day of desulfurizer connection, it gets better every day. In addition, information about the indicator on car batteries is in the video.
I did not change the water in the battery anyway, I have not researched it yet as it would be a bit difficult in this type of batteries. I mounted the desulfurizer circuit on a large cooler, the cooler was sufficient, no fan was needed.
I will add the results to the article after a month.
Current values: I did the load test again a few days later, it lasted 2 hours and 15 minutes, and my last test lasted 3 hours and 10 minutes. After that, I stopped the desulfurizer process, this value is very good, according to calculations, a zero battery lasts about 4 hours with a 10 amp load.
Publication date: 2024/12/17 Tags:
