Several control applications lamp, motor, electronic devices, etc.. you can use 12-channel isolated triac MOC3041 motorola module card .. Insulation work done by theriac drive instead of being used BT136 BT138 triacs or leg connections matching the triac used. Look circuits, uncluttered layout elements idc types of signal input through the socket while the other parts are made out of two terminals `s ..
Meanwhile triac metal parts of the case are associated with a central leg in these areas are high-voltage circuit, be careful when running tests
Source: mirley.firlej.org/uklad_wykonawczy_12tr
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18908.zip
Published: 2012/05/16 Tags: power electronic projects
2.1 Amplifier Project TDA2050
2+1 Amplifier Project using tone controls have the feature of entries 3 tda2050 ne5532 op amplar used 32w per channel power can give. Çaslışma symmetric DC voltage of the amplifier circuit 2x25v TDA2050 symmetric (transformer: 2x16v ac 100w) considering the power drop leg links is the same as the tda2040, can be used to control or filter or tda2030 lm1875 times you can use a different 2.1 amplifier circuits.
