100 Watt Amplifier Circuit TDA7294 PCB
| Updated on June 22, 2014
TDA7294 integrated amp is pretty popular in a very sound system is being used. Has a very clean sound. The materials used in the circuit with very little a few passive components are easy to install.
TDA7294 100V – 100W DMOS AUDIO AMPLIFIER WITH MUTE/ST-BY
  • Very high operating voltage range (±40v)
  • Dmos power stage
  • High output power (up to 100w music power)
  • muting/stand-by functions
  • No switch on/off noise
  • No boucherot cells
  • Very low distortion
  • Very low noise
  • Short circuit protection
  • Thermal shutdown
TDA7294 Amplifier Circuit Schematic
100watt-anfi-devre-semasi-tda7294
TDA7294 Power Supply Schematic
100watt-anfi-besleme-power-devresi
Transformer 120w 2x25v (*)
1 x 1 amp fuse (220v transformer for input)
2 3.15 amp fuse (transformer outputs)
D1 … D4 1N5404 4 pcs (for DC Rectifier)
2 R1 .. R2 2.2K resistor (red-red-red)
C1 .. C2 1000uF 50v 2 (in the scheme looks 1000uF 10uF is better;))
2 … Led LED1 LED2 (you can use if you want to display is used for)
As indicated in the circuit diagram of the circuit power transformer power 200w 100w to 100w is 200w but it was more necessary to use higher cost of a transformer is high. Please use the transformer 120w 200w or 500w transformer but have ready in your hand while they’re being used in six 100w is important to integrate the supply voltage does not exceed the working voltage can evaluate trafoyu enough to get your hand.
TDA7294 integrated amp maximum working voltage of + – 40 volts DC + -10 volts DC while the lowest operating voltage transformer can evaluate accordingly in your hand, of course, could not provide low-voltage power 100w consider
TDA7294 PCB Top
100watt-anfi-pcb-ust
TDA7294 PCB Bottom
100watt-anfi-pcb-alt
TDA7294 Mute/Stantby Connection
100watt-anfi-swic-anahtar-baglantisi
source : http://www.stavebnice.richardvacula.com/select.php?link=PT002
Publication date: 2008/01/13 Tags: , , ,
2 Comments “100 Watt Amplifier Circuit TDA7294 PCB
    Microcontroller Controlled Robot Projects
    Multi-robot projects have been realized with the microcontroller. In addition to professional practice ‘projects have simple robot Most of the projects in the PIC16F series microcontrollers used ATMEL series over with no project varieties plenty sumo robots, line following robot, rope climbing robots, crawling robots also Turkish thoroughly robotics Anlatımları interested in this subject people to work will cleave.
    A few examples robot project
    Der integrierte Verstärker TDA7294 ist sehr beliebt, wenn ein Soundsystem verwendet wird. Hat einen sehr sauberen Klang. Die in der Schaltung verwendeten Materialien mit nur wenigen passiven Bauteilen sind einfach zu installieren.
    TDA7294 100 V – 100 W DMOS-AUDIO-VERSTÄRKER MIT STUMMSCHALTUNG / ST-BY
    Sehr hoher Betriebsspannungsbereich (± 40 V)
    Dmos Endstufe
    Hohe Ausgangsleistung (bis zu 100 W Musikleistung)
    Muting / Standby-Funktionen
    Kein Ein- / Ausschaltgeräusch
    Keine Boucherot-Zellen
    Sehr geringe Verzerrung
    Sehr leise
    Kurzschlussschutz
    Thermische Abschaltung
    TDA7294 Verstärkerschaltplan
