Power supply circuit consists of a few sections 04 to 0 30v power supply based on solid TL081 op amp circuit 2N3055 power transistor quite popular and a classic by many people applied. LCD display on the floor (AVT2857) the ATmega8 microcontroller used voltage, current imaging as well as the DS18B20 sensor heat thanks değerinide Viewing writer in addition to constant 12v 5v output as add in, this output for the PC power supply use would be more practical for the project PCB, schematics and source code files There
Source: elektroda.pl/rtvforum/topic2230884.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18925.zip
Published: 2012/05/20 Tags: atmega8 projects, avr project, microcontroller projects
Transistor Amplifier Circuit 250W 2SC3858
250 Watt amp circuit previously shared 2x100W circuit developed beefed supply voltage 2x75v DC symmetrical in total 150V working with the output transistor-the 2SC3858 this transistor is not found instead 2sc5200 used in this case, the number of transistors necessary to increase or very good cooling to do the PCB drawing layout assembly supply circuit all information provided in critical areas including .. also making measurements of voltage values should be shown with photos
