Winamp IR control Circuit VisualBasic PIC16F627 RS232
| Updated on July 30, 2024
Winamp can be used to control a variety of programs with some ready-made controls, but these controls are difficult to find compatible IR control circuit and control the problem disappears.
IR transmitter circuit 16f627 microcontroller is based on the 6 button control receiver circuit MAX232 and IRM8061 doing eye catching and consists of a few passive components. The eye catching enough to connect the different models used in the right leg
Prepared by the C language source code of the circuit and control software source code in Visual Basic are prepared. Winamp outside the control circuit can be useful in different projects.
IRM8061-winamp-remote-kumanda-ir-verici-rs232-vb
Source: goo.gl/tBOE IR control Winamp circuit files Alternative link:
Publication date: 2010/09/06 Tags: ,
1 Comment “Winamp IR control Circuit VisualBasic PIC16F627 RS232
    Digital Servo Motors Interface Circuit PIC16F877
    Servo motor control unit to control two’s. While the other one circuit pic16F877 16f876 circuits based on the communication with the computer via RS232 serial port is doing. Kazırl backed by Assembly PCB software and schema files are made ​​with eagle.
    Servo motor control circuit
