Any with a remote control relay to control prepared a simple circuit application CD4017 CD4069 integrated based on the microcontroller is not used it dez has advantages, but the programming work to deal with people who prefer not an ideal circuit diquat should be TFME5260 IR receiver sensor best to position the writer circuit ceiling lamp used to turn the relay output is used for the CD4017 can be controlled in different devices .. Project has started drawing eagle schematics and pCB ..
Source: dakki.byethost31.com/podstrony/elektronika/zdalne.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18964.zip
Published: 2012/05/22 Tags: analog circuits projects, simple circuit projects
Wave Reader Circuit AT89S52 Flash Memory
PIC24, 32, MSP430 is progressing rapidly but AT89S52 time, I still made sure that what is in use by 8051. In this project, kingston 8gb flash memory is read in the wav files (wav player circuit ) TBA820 AT89S52 output amplifier with integrated audio signal is given to powered speakers ..
