An all-in-one advanced programming circuit. The programmer works via USB port. Since the circuit is USB-supported, a controller was used for control: pic18f2550, but the author mentioned that it can be adapted to other controllers upon request, so I recommend 18f2550, after all, the schematic, pcb and software are accordingly. The most important feature that distinguishes the circuit from other programmers is that it is open source, it can be programmed with Pic Micro as well as Atmel controllers and can run on Windows and Linux.
All in One USB Programmer PIC18F2550
Author project “Open Programmer” has given the name of a super programmer all the source code of open source developers will be great for those given via computer software programs developed with C + + to throw even have the resources.
Also prepared with Eagle PCB, schematics and source files 18F2550 hex driver software’s files. Open Programmer detail page (english) information used for circuit calculations, formulas, graphs and more oscilloscope’s measurement
Support for an integrated; (bold black text than those who have not been tested)
10F200, 10F202, 10F204, 10F206, 10F220, 10F222,
12F508, 12F509, 12F510, 12F519, 12F609, 12F615, 12F629, 12F635, 12F675, 12F683, 16F505, 16F506, 16F526, 16F54, 16F610, 16F616, 16F627, 16F627A, 16F628, 16F628A, 16F630, 16F631, 16F636, 16F639, 16F648A, 16F676, 16F677, 16F684, 16F685, 16F687, 16F688, 16F689, 16F690, 16F716, 16F73, 16F737, 16F74, 16F747, 16F76, 16F767, 16F77, 16F777, 16F785, 16F818, 16F819, 16F83, 16F83A, 16C83, 16C83A, 16F84, 16C84, 16F84A, 16C84A, 16F87, 16F870, 16F871, 16F872, 16F873, 16F873A, 16F874, 16F874A, 16F876, 16F876A, 16F877, 16F877A, 16F88, 16F882, 16F883, 16F884, 16F886, 16F887, 16F913, 16F914, 16F916, 16F917, 16F946,
18F242, 18F248, 18F252, 18F258, 18F442, 18F448, 18F452, 18F458, 18F1220, 18F1230, 18F1320, 18F1330, 18F2220, 18F2221, 18F2320, 18F2321, 18F2331, 18F2410, 18F2420, 18F2423, 18F2431, 18F2439, 18F2450, 18F2455, 18F2458, 18F2480, 18F2510, 18F2515, 18F2520, 18F2523, 18F2525, 18F2539, 18F2550, 18F2553, 18F2580, 18F2585, 18F2610, 18F2620, 18F2680, 18F2682, 18F2685, 18F4220, 18F4221, 18F4320, 18F4321, 18F4331, 18F4410, 18F4420, 18F4423, 18F4431, 18F4439, 18F4450, 18F4455, 18F4458, 18F4480, 18F4510, 18F4515, 18F4520, 18F4523, 18F4525, 18F4539, 18F4550, 18F4553, 18F4580, 18F4585, 18F4610, 18F4620, 18F4680, 18F4682, 18F4685, 18F8722
24F04KA200, 24F04KA201, 24F08KA101, 24F08KA102, 24F16KA101, 24F16KA102, 24FJ16GA002, 24FJ16GA004, 24FJ32GA002, 24FJ32GA004, 24FJ48GA002, 24FJ48GA004, 24FJ64GA002, 24FJ64GA004, 24FJ64GA006, 24FJ64GA008, 24FJ64GA010, 24FJ96GA006, 24FJ96GA008, 24FJ96GA010, 24FJ128GA006, 24FJ128GA008, 24FJ128GA010, 2400, 2401, 2402, 2404, 2408, 2416, 2432, 2464, 24128, 24256, 24512, 241025, 25010, 25020, 25040, 25080, 25160, 25320, 25640, 25128, 25256, 25512, 251024,
93S46, 93×46, 93x46A, 93S56, 93×56, 93x56A, 93S66, 93×66, 93x66A, 93×76, 93x76A, 93×86, 93x86A,
AT90S1200, AT90S8515, AT90S8535, ATmega8, ATmega8A, ATmega8515, ATmega8535, ATmega16, ATmega16A, ATmega32, ATmega32A, ATmega64, ATmega64A
12C508, 12C508A, 12C509, 12C509A, 12C671, 12C672, 12CE673, 12CE674
Source: http://openprog.altervista.org/OP_eng.html All in One Programmer alternative link:
Published: 2010/03/08 Tags: pic18f2550 projects, programmer circuit
PC Servo Motor Control with PIC16F84 RS232
Servo motor control circuit assembly prepared with software installed on PIC16F84 microcontroller. Computer monitoring software designed with Visual Basic can control 8 low-power servo motor circuit and the communication between the PC via RS232 serial port built
The program is written in VISUALBASIC and comes complete with source so you can personalize the interface. The circuit uses the popular PIC 16F84, on it there is also a very simple interface for dialogue with the PC via RS232.
RS232 Servo Motor Contro
