DC DC converter circuit UC3843 SMPS PWM control integrated on the board 10v 16v DC Voltage 12V 30V turning out 16v is set to 3 amps can give used in the circuit of the coil value 20mh coil wrap is necessary to toroid core PC power supply can be obtained from
The operation is based on controlling the pulse width (PWM), which is laden an IQ of special family UC384X Different family members will differ in the working temperature, voltages activation and deactivation, precision work and the highest ratio of width pulse.
UC3843 DC DC Converter Circuit
Source: soloelectronica.net/
Published: 2008/08/18 Tags: dc dc converter circuit, power electronic projects
Proteus isis Library Archive
Earlier in writing Proteus isis isis Library Model File can use in model simulations and I shared library files new files have not been able to debug with the old files from the list may be the same ones you can control
