Simple Transistor Fan Speed ​​Control Circuit
| Updated on June 21, 2014
Fan speed control circuit 4 bc639 transistors are used on the circuit speed can be adjusted with potentiometer 47k. Intel CPU fan circuit used in the circuit tests based on phenolic hole about a new simple circuit for the low cost ..
cpu-fan-speed-control
Source: http://www.soloelectronica.net/fan_espeed_control.html
Publication date: 2011/10/29 Tags: ,
1 Comment “Simple Transistor Fan Speed ​​Control Circuit
    500W Power Amplifier Circuit Apex B500
    Apex B500 power amp’s pcb design stylish been output mje15032 and mje1503 power transistors used supply voltage symmetrical 55v … 90V from quite high dangerous circuit tests, be careful addition amphitheater to be used with fan control and protection circuit diagrams and PCB drawing is on.
