TDA1524 with the bass, treble, balance, volume control and p cad gif. Pcb circuit drawing available in print format
LM1036 circuits built with 3 pieces of different circuit to only pcb drawings of different integrate these most prominent feature of the two-channel stereo that despite mono potency use bim adjustments bass (bass), high-pitched (treble), balance (balance), volume settings, single-channel mono with potentiometer also “LOUDNESS” control located in the lower bass sound strengthens this control
In addition, the control circuit opamp made with two different shades available in pcb drawings
TDA1524 Tone control circuits
Power supply 15,0-40,0 In
Current 45 mA
The band 20-20000 Hz
Noise voltage 100 mV
Input impedance> 30 kOhm
Output impedance: 300 ohms
Harmonic ratio: 0.3%
LM1036 Tone control circuits
Wide supply voltage range, 9V to 16V
Large volume control range, 75 dB typical
Tone control, ±15 dB typical
Channel separation, 75 dB typical
Low distortion, 0.06% typical for an input level of 0.3 Vrms
High signal to noise, 80 dB typical for an input level of 0.3Vrms
Few external components required
Tone control circuits tl074 lm833 lm1036 tda1524 all files:
Published: 2008/01/12 Tags: audio control circuits
Switch Mode Power Supply SMPS Circuits Archive
Heavy bulky transformers larger than a perfect invention SMPS circuit of us saving electronic power supplies SMPS circuits more heavily on you, like me if you are interested we also have plenty of practice and two SMPS Design
My favorite part of the power electronics, SMPS, or simply say I’m dealing with this business for a long time ONTEK’s very different systems now let’s take a look at a wide range of applications archive
13 volts, 40 volts 0.5 amps to 3.3 amps hold on power in various voltage Switch Integrated circuits made with most modern in all of this super power transistors integrated control section and so on. is now a classic, of course, indispensable SMPS PWM-controlled applications have been designed with integrated SG3525, TL494, UC3842 also used in desktop computer power supply pcb circuit diagrams galore …. 400w 200w ATX AT
Klangregelkreise tl074 lm833 lm1036 tda1524
TDA1524 mit dem Bass, Höhen, Balance, Lautstärkeregler und p cad gif. Pcb-Schaltungszeichnung im Druckformat verfügbar
LM1036 Schaltungen mit 3 Stück verschiedenen Schaltung zu nur pcb Zeichnungen von verschiedenen integrieren diese prominentesten Merkmal der Zwei-Kanal-Stereoanlage, die trotz Mono Potenz verwenden Bim Anpassungen Bass (Bass), hohe (Höhen), Balance (Balance), Lautstärkeregelung, Einkanal-Mono mit Potentiometer auch “LOUDNESS” -Regelung im unteren Bass-Sound verstärkt diese Steuerung
Darüber hinaus ist der Steuerkreis opamp mit zwei verschiedenen Schattierungen in pcb Zeichnungen erhältlich
