Modified ATX Power Supply Half Bridge SMPS Project TL494 EI33
| August 30, 2023 Updated
Half bridge SMPS circuit is a modified version of the ATX computer power supply circuit. Output power transformer ei33-rewound for symmetrical high voltage. Its power is 300 watts input voltage 240v ac output voltage + – 20volts + – 45volts adjustable.
It can be used in ER34…ER35 transformers. You can only test the TL494 control module by printing the PCM and arranging the ready ATX power supply.
It can be used to run high-power amplifier circuits. Additional tone control preamp circuits include 7812 positive and 7912 negative voltage regulator integrated with +- 12volt output.
TL494 300W SMPS Update and 800W Version
The SMPS Circuit made with TL494 has been updated, PCB arrangements and soft start improvements have been made. Theoretical output power: 250W with EI33-23-13 core transformer Controller frequency: 160Khz Adjustable output voltage +-24 to +-42V
SMPS 800W Version made with SG3525 pwm control IC, IR2110 mosfet driver is used in the primary driver part Theoretical output power: 800W with EE42 core transformer 1KW with EE42 / 21/20 core transformer Controller frequency: 210Khz Output voltage approx. + -24V to + -42V
Amplifier SMPS 300W 800W power supply circuits have PCB and schematic drawings, in addition, transformer winding and other information are written in the note file. (TL494 version has been run by many people)
TL494 SMPS Circuit Modified ATX Power Supply
tl494-300w-smps-v3
sg3525-800w-smps-ir2110
atx-smps-150x150 smps-tl494-ei33-2-150x150
switching power supplies are ideal for powering audio amplifiers. Present the possibility of regulating the output voltage secondary, tertiary and further incorporate fixed outputs (+ -15 [V]) for feeding filters, preamps, etc..
The use of switching sources such avoids the need for costly, heavy and bulky current transformer, plus grinding and filtering steps corresponding. All necessary information, schematics, PCBs, etc. are located in their respective files.
Compact SMPS power supply: – Theoretical output power: · ~ 250 [W] core IE33-23-13 (typical ATX).- Frequency Driver: 160 [kHz] approx. – Adjustable output voltage + -24 to + -42 [V] approx.- Tertiary fixed voltage outputs (+ -15 [V]).
Source: forosdeelectronica.com Modified ATX SMPS circuit schematic pcb files alternative link :
Published: 2010/02/16 Tags: , , , ,
1 Comment “Modified ATX Power Supply Half Bridge SMPS Project TL494 EI33
